Dash lights on
Old Dec 9, 2010 | 09:39 AM
G35-Dan's Avatar
Dash lights on
Started the car this am and the ebrake, VDO off, and SLIP (dif) lights all stayed illuminated. Shut it off, started again and same issue. Anyone seen this before? Fuse issue?
Old Dec 9, 2010 | 10:00 AM
PAIXAO's Avatar
Check your brake fluid. Your pads may need replacing soon.
Old Dec 9, 2010 | 10:31 AM
G35-Dan's Avatar
Thanks for the quick response. Low fluid would trigger those three lights? Pads do need replacing soon...
Old Dec 9, 2010 | 10:34 AM
PAIXAO's Avatar
Well, when the pads are low, more fluid is necessary to compress the piston lowering the fluid level. Yes, all 3 lights will be triggered when this happens.
Plur
Interior
May 22, 2019 04:35 PM
deschutes606
Jul 18, 2018 09:34 PM
wonderizm
Sep 24, 2015 03:09 AM
06G35Kurtis
Aug 23, 2015 12:24 AM
