Window Problem
Window Problem
Hi Im new to the forum. I have an 03 g35 coupe and am having problems with the passenger side window. When standing outside of the car you can see that the window is not sitting flush with the rest of the car. It sticks out about a 1/4 of an inch or so, which the driver side window does not. As a result I am getting significant wind whistle at speeds above 60 mph. Also, the window feels more loose than the driver side. If you wiggle it when it is in the up position, it has more movement than the driver side.
I am guessing that the problem is that the window is out of alignment inside the door cavity. Has anybody had this problem or know of a fix?
