Spark Plugs at 60K
Old Feb 21, 2011 | 11:17 AM
infinitig35's Avatar
Spark Plugs at 60K
Hey guys, my car is about to hit 60K miles in the next month or so. Should I be proactive and change the plugs? If I do end up changing the plugs, should I also change the coils? The car is an '03.
Old Feb 21, 2011 | 12:44 PM
lsmooth81's Avatar
It doesn't hurt to change it. I change my at 65K because my warranty was getting ready to expire and I wanted to find out if I had oil leaking into my sparkplug. It was so I had the dealer replace the valve cover under warranty. You could leave the coils.
Old Feb 21, 2011 | 07:16 PM
JAYRIPPA420's Avatar
its good to change them at 100k, the car manual states that. ive heard that somehwere..not positive.im sure it cant hurt though.
Old Feb 22, 2011 | 12:47 AM
lsmooth81's Avatar
It does say to change at 100K, but our cars are known for faulty valve cover, so if you wait to 100K, the damage could be worst than finding it early.
Old Feb 22, 2011 | 12:49 AM
thescreensavers's Avatar
Mr.202?
^ Yep
+1
Old Feb 22, 2011 | 02:32 AM
sillyoldtayo's Avatar
+2 on changing early. I changed mine out at 48k. The idle smoothed out a bit with the new plugs in.
Old Feb 22, 2011 | 10:24 AM
whats plugs do ppl use?
Old Feb 22, 2011 | 10:49 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
The car comes with NGK platinums. Some people replace them with NGK iridiums. The upper hand hasn't been proved for either plug.
Old Feb 22, 2011 | 01:14 PM
Tru so wouldn't u say it's better to replace with oem??
Old Feb 22, 2011 | 04:15 PM
4DGS's Avatar
^ doesn't matter either way. They all do the trick.
Old Feb 22, 2011 | 05:02 PM
Word
Old Feb 23, 2011 | 09:55 AM
So how come iridium cost more than platinum?
Old Sep 20, 2011 | 07:27 PM
exiledtrinib0y's Avatar
yea i'm at 69000 miles gonna change plugs just to see if i got oil in my no. 6 plug. i'm already taking the car to dealer for back windows warranty repair.
Old Sep 21, 2011 | 05:48 PM
william747400's Avatar
Iridium plugs are suppose to last longer
Old Sep 28, 2011 | 01:46 AM
vigman's Avatar
I changed out my GF's sedan ( 86K ) & my coupe (97K) and they NEEDED new plugs..
And they were BOTH original.. we're getting SLIGHTLY better gas milage and a bit smoother idle... most importantly the plugs were REALLY hard to get out, lots of carbon up the threads due to ( I assume ) being a bit to loose on install.. but new plugs & anti seize took care of that.
Mike
