Would this be considered normal?
Old Feb 23, 2011 | 11:58 AM
hologram's Avatar
Everytime I park my car(07, g coupe/AT), no matter where it is, it makes clicky noises that seem to come from underneath the car. I searched long thru the forums and couldn't find anything on this problem.
Sometimes at idle, I can hear the popping sounds. My old car, a buick lacrosse, only made that noise at the exhaust because the metal was contracting being cooled off. So i don't know if its still the exhaust that causes it, or if its something else.
Any tips would be appreciated!
Old Mar 7, 2011 | 05:16 PM
pck823's Avatar
Clicky noises are typically exhaust components heating up/cooling off. One thing I could recommend is to drive the car and get it to normal operating temps then see if you can hear the same noises at idle. If you can still hear these noises at idle, then you have to determine if the noise is either engine RPM sensitive or vehicle speed sensitive.
I can't speak for G's as I'm still looking to buy one, but if RPM sensitive, then I would be looking at the tranny or torque converter as culprits. If the noise is vehicle speed sensitive, then look at driveshaft/rear end.
Hope this helps in some way.
Old Mar 31, 2011 | 09:38 PM
strykez's Avatar
the crackling will be from contracting of parts. most likely your exhaust
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
BradMD_96
Oct 6, 2015 09:31 AM
aaron3719
Sep 29, 2015 10:12 AM
vamarris
Sep 26, 2015 12:56 PM
