grinding at low speeds..
Old Jun 2, 2011 | 12:41 PM
G35phile's Avatar
My 04 G35 has a grinding at speeds under 10 MPH. Is there a cure or fix for this
Old Jun 2, 2011 | 01:24 PM
Stryde's Avatar
Does it only happen right after you've started the engine and begin to accelerate? If so, that's normal -- it's the ABS self test.
Old Jun 2, 2011 | 03:10 PM
G35phile's Avatar
No... its overtime I slow down to stop....and takeoff again....its everytime
Old Jun 2, 2011 | 03:22 PM
G35phile's Avatar
The brakes pads and rotors have been changed. The right wheel bearing hub was changed. It's always grinding when taking off and braking under 10 mph....it does it at every stoplight.. any ideas
Old Jun 2, 2011 | 04:05 PM
nghiars's Avatar
were the pads and rotors bedded correctly when you replaced them? if not you may need to re-surface both pads and rotors and follow the bedding process.
Old Jun 2, 2011 | 07:15 PM
G35phile's Avatar
Does bedding really make a difference. The brake companies say no it doesn't... even brembo says no
Old Jun 2, 2011 | 07:27 PM
nghiars's Avatar
it depends on the parts you bought. if they have already been bedded by the manufacturer, then you wouldnt have to.
Old Jun 7, 2011 | 10:51 PM
Cooldude04's Avatar
I have the same problem with my 04 coupe too G35phile. My car makes that grinding noise only on the front passenger side and it pulls slightly to the right. Does your do the same thing???
Old Jun 8, 2011 | 09:21 AM
G35phile's Avatar
Mine doesn't pull.....but the rest yes
Old Jun 11, 2011 | 10:35 PM
Cooldude04's Avatar
Did you fix your problem G35phile? Was it the wheel bearing?
Old Jun 12, 2011 | 08:35 AM
G35phile's Avatar
Nope..... It still has the noise.......the bearings were changed. The brakes have been replaced......any other ideas
Old Jun 12, 2011 | 09:55 AM
Cooldude04's Avatar
Did you check the compression rod bushings? Try to lupe swaybar bushings? See if that helps
Old Jun 12, 2011 | 10:09 AM
G35phile's Avatar
Why would it do that at low speeds
Old Jun 12, 2011 | 10:17 AM
Cooldude04's Avatar
I believe the compression rod bushing will cause squeak and other noises if they're worn out. I checked my car and the right front bushing was ripped, i bought a new set of Energy bushing to replace it. Will post the update when i'm done.
Old Jun 12, 2011 | 10:19 AM
Cooldude04's Avatar
Your car might have something else not the CR bushing, just give it a quick look since you've already replaced the wheel bearing and breaks.
DRG35R
Jan 31, 2016 07:14 AM
aaron3719
Sep 29, 2015 10:12 AM
wow600rr
Sep 28, 2015 11:50 AM
Detailed Image
Sep 28, 2015 07:04 AM
alinero718
Sep 27, 2015 09:35 PM
