Engine
Old Sep 25, 2011 | 02:33 PM
pachieng's Avatar
Engine
I put in a new battery the other day and since then my car shuts off everytime i start it. i Checked my alternator and its working fine. I have no error codes......I don't know whats going on i think its a syncing issue....help
Old Sep 28, 2011 | 01:50 AM
vigman's Avatar
Sounds like you blew a fuse.. somewhere.. the intelligent fuse panel is behind the battery.. did you bump that? Did you clean out the battery area with soap & water?
How are the battery connections? You do know the main battery terminal ( positive ) has 4 or 5 fusible links built in..?
Mike
Freeman186
Sep 6, 2023 10:07 AM
alessandro
Oct 8, 2015 09:29 AM
Joe Gargano
Sep 18, 2015 11:17 AM
AT23
Sep 15, 2015 07:44 PM
AuAltima3.5
Sep 13, 2015 10:53 AM
