Warnings on car randomly come on
Old Oct 5, 2011 | 07:27 PM
saltyload's Avatar
While I was driving on the highway (somewhat hilly, slightly wet road) the brake light came on, VDC off came on, and Slip came on. Brake fluid was fine and hand brake was not engaged. I was driving about 55mph going straight. However, it turned off after driving for an hour. The tire pressure light keeps coming on for no reason as well. Is there any fix for this?
Old Oct 7, 2011 | 05:45 AM
monteitis's Avatar
Not sure about the vdc/slip issue, but my tire pressure light consistently comes on for no reason if I drive non-stop for about 45 minutes.. I've read about other members having the same issue.
Old Oct 7, 2011 | 10:37 PM
saltyload's Avatar
any way to get the TPM light to work properly?
Old Oct 15, 2011 | 01:51 AM
djfarhan's Avatar
https://g35driver.com/forums/v36-bra...ts-coming.html
Old Oct 15, 2011 | 01:59 AM
nawalvicky's Avatar
i read sumthing also about this. They said it can also occur by water build up underneath the battery. There is a fuse box. There just check it and make sure there is no water.
Hasanbaloch
Feb 29, 2024 08:45 PM
ghost_g35
Aug 7, 2015 10:31 AM
BlueBelleG35x
Jul 23, 2015 02:10 PM
mjfenix
Jul 17, 2015 02:07 PM
