Clearing codes resetting ecu?
Old Oct 7, 2011 | 05:50 AM
monteitis's Avatar
I'm aware of the pedal sequence to reset the ecu, but was wondering if clearing fault codes with an obd scanner actually resets the ecu, or if it simply just clears fault codes?
Thanks!
Old Oct 9, 2011 | 05:01 PM
vigman's Avatar
It just clear the codes...
Mike
Old Dec 16, 2011 | 11:00 PM
power2rice's Avatar
actually, to correct what mike said, obd2 reset does reset the ecu completely. with the obd 2 diag tool it, after you choose to erase, all the drive cycles in memory and you must drive the car for 30 or so miles before sensors such as o2, egr, etc complete it's cycles again. whether you use the obd2 tool or do it manually, it does the same thing, resets the ecu.
Hasanbaloch
Feb 29, 2024 08:45 PM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
Silver tiburon
Sep 4, 2015 07:17 PM
stay_tuned
Jul 21, 2015 07:09 PM
kenthung
Jul 21, 2015 05:56 AM
