Service Engine Soon light comes on again soon after
Old Oct 16, 2011 | 07:04 AM
ClutchBurner04's Avatar
So I just got one of my O2 sensors replaced because the SES light came on. About a week after the O2 install, the SES light comes back on...
I wondering what's going on now. I just changed me oil prior to the O2 sensor change, but that light doesn't come on for maintenance problems. I am stock everything.
Would Nissan/Infiniti do free error code checks? I'm flat broke here lol
Any help would be appreciated!
Old Oct 16, 2011 | 03:58 PM
vigman's Avatar
ODB-2 diagnostics
I would first take it back to where the work was done...
If not, most chain auto stores will do a free diagnostics ( in the hopes to sell you something ).
Mike
Old Oct 17, 2011 | 01:03 AM
Yeah I'm going to definitely bring it back to them. The problem is that they can't read the error codes so I do have to find an auto store with free diagnostics.
Old Oct 17, 2011 | 01:31 AM
hurleyguys's Avatar
damm what garage doesnt have an OBDII scanner?
Old Oct 17, 2011 | 11:53 AM
lol they're new. They just started their own shop but I've been going to them for awhile.
Old Oct 17, 2011 | 04:56 PM
Sharpdagger's Avatar
I'm not trying to high-jack your thread,
....... I have the same "service engine soon" .......
I have just changed my oil and filter, and also replaced
the spark plugs. The car has always run real strong, smooth idle, no mechanical issues. (battery cable removed during spark plug change)
soon after starting the car,
to check the oil. The service engine light came-on.
The car runs and pulls harder now then it did before. The old plugs were definitely worn and the gaps was worn to anywhere between 0.055" to 0.070".
new plugs were gapped to 0.044" per spec's.
any info would help ! Thanks...
2005 G35 sedan 96,170mi.
Old Oct 25, 2011 | 11:54 PM
The light just magically turned off yesterday.
Should I go for an emissions test?
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
derres
Aug 28, 2015 03:27 PM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
mjfenix
Jul 17, 2015 02:07 PM
