90 K Maintenance
Old Oct 24, 2011 | 11:05 AM
jonblizz's Avatar
90 K Maintenance
So i bought the G35X Auto at 66k miles , now im at 87 k. So now Im thinking about the 90 k maintenance
Im not sure if the proper maintenance was done at 60kin particular the tranny maintenance. I Do have an aggressive driving style , IDK how u could drive this car and drive it slow !!
Anyways Ive had bad experiences with my old accord with the tranny. And i know this is not a honda , but i am a lil anxious when possibly having problems with the tranny.
So with that being said im probably gonna go to the stealership to have the work done .
How much should the 90k service run and would you have the tranny serviced at this point or just say **** it .
As it stands now the tranny feels great, but i know from experience with my honda that could all change after fluids are changed
Old Oct 24, 2011 | 03:42 PM
Jordan00711's Avatar
You should go ahead and do the serivice work, hell do it your self and save some $$$. There's DIY's on here for all of it. I did all mine when I bought the car just as peace of mind kinda thing. Flushed and replaced the coolant, tranny fluid, and the rear dif. fluid. Also check your belts and sparkplugs and replace them as necessary.
Old Oct 24, 2011 | 05:07 PM
Lone Wolf's Avatar
For my 90k service which I will be doing soon I will be flushing the radiator, differential, power steering, brake fluid,(all with Motul) tranny(OEM Fluid). I will also be changing my in cabin micro filter, a throttle body cleaning and having my fuel injectors cleaned. Also I will be having any type of lubrication done, and check for any type of leaks or any type of missing hardware( i.e. bolts, nuts, washers, cotter pins, etc), and get my windshield wipers replaced. I would start there. If your gonna take your car to the dealer I would take it to a Nissan dealership, it will be cheaper. And I would definitely at least drain and fill the tranny fluid. Call to get a quote if you want to get an idea of how much you are looking at spending.
Marlin84
Apr 1, 2020 12:52 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
c_elliott83
Sep 25, 2015 07:55 AM
DRG35R
Sep 16, 2015 05:33 AM
