2003 G35 coupe acceleration problem
Old Feb 1, 2012 | 12:08 PM
Dooki3butta's Avatar
So my coupe is a 6 speed and it feels like something is holding my car back from accelerating. It feels like it has no power at all. I had the throttle body cleaned and did a system flush and the problem is still there. Any ideas???
p.s.- no engine light or any lights on in the dash
Old Feb 1, 2012 | 12:43 PM
opata's Avatar
I had a similar problem with a bmw m3. The timing chain was stretched throwing the timing off. The chain broke and the engine blew
Old Mar 5, 2012 | 04:58 PM
Mobydick's Avatar
Not sure if you've found the problem yet but you may want to check/replace the spark plug wires. I had a mits that did the same thing and after I replaced the wires, it went back to normal.
Old Mar 5, 2012 | 11:42 PM
leanlikeacello's Avatar
buy a turbo
Old Mar 6, 2012 | 12:12 AM
Eric@TCGMiami's Avatar
Clogged cats?
Old Mar 6, 2012 | 12:25 AM
VQ35 revv's Avatar
Is the lack of power through the whole RPM range? Any strange sounds at idle and/or full throttle?
And how bad is your lack of power?
Old Mar 8, 2012 | 12:21 AM
luisp88's Avatar
this happened to my not to long ago, i have a 5AT and my exhaust(stock) was louder and there was a huge lose of power and no cel light. i took it to a mechanic who said it was due to a clogged catalytic, so i ordered test pipes and new exhaust and have been happy ever since.
btw i cleaned maf sensor, new spark plugs, put back oem intake, checked for vacuum leak before i took to mechanic
Hasanbaloch
Feb 29, 2024 08:45 PM
TWASkyliner
Feb 8, 2020 08:00 PM
R350k5
Oct 1, 2015 08:41 PM
Chattzx
Jul 17, 2015 11:23 AM
