AT cont fuse keeps blowing
Old Apr 8, 2012 | 01:25 PM
jadis2230's Avatar
Hey I just wanted to know if anyone has encountered the same problem and how to fix it.
My at cont fuse blows every time I start the car and car will not go into gear. I have been trying to trouble shoot this for days and haven't found a solution. Any help would be greatly appreciated
Old Jun 8, 2012 | 01:18 PM
lostangels01's Avatar
Found this:
http://forums.nicoclub.com/ecu-cont-...g-t506450.html
Old Jun 8, 2012 | 02:32 PM
GAU-8's Avatar
Have you had the pan off the tranny previously? If so, it's possible the wires to VB solenoid could be pinched.
Old Jul 8, 2012 | 01:16 AM
G35_DAN's Avatar
Check your trunk harness...more than likely there are a few broken wires in there that are shorting out causing the fuse to pop. The break will be in the rubber portion, at the right rear trunk strut. Open it up, and see what you find...
If you replace the fuse and just start the car, it will not pop, right? But as soon as you step on the brake pedal, or shift into "R", the fuse pops, and the shift indicator on the dash disappears, right? If this is the case, your trunk harness is broken.
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
JLee301
Sep 25, 2015 08:46 PM
master111
Sep 25, 2015 08:32 PM
2014g35x
Sep 11, 2015 07:53 PM
