compass issue
Old May 15, 2012 | 11:55 AM
raikage's Avatar
compass issue
hey folks i recently put in a double din radio in my 03 g35 coupe witch works great all plug an play harness, after the install i noticed the compass is MIA has any one had this problem only the temp is being displayed or all the climate stuff when i turn it on, i already searched an all i found is how to adjust it any help would be appreciated
Old May 15, 2012 | 08:40 PM
05_SkylineSedan's Avatar
20 Year Member
ideas:
#1. 2005/6 has a button to press to toggle the compass display on and off...
#2. It shares a fuse with several other things so you would probably notice other things not working if that was the problem.
#3. Maybe the actual compass unit got unplugged or lost a ground while you were rewiring?
Old May 19, 2012 | 11:48 AM
raikage's Avatar
Originally Posted by 05_SkylineSedan
ideas:
thx a lot for the help it was the fuse then had to push the button to turn it back on witch i had tried first
G35Rican
Jul 31, 2024 01:37 AM
yosip1115
Sep 9, 2015 03:30 PM
socaldavid
Sep 5, 2015 04:35 AM
kevintandmd
Sep 3, 2015 06:41 PM
UT G35
Sep 3, 2015 03:58 PM
