detonation
Old Jun 23, 2012 | 04:44 AM
N8digity's Avatar
detonation
so i had a base dyno to see what my power and torque ratings were and while the car was running the tuner heard detonation in 6k-7k rpm range . is there a way to defeat this issue with running a hks f-con or something similar to that ?
Old Jun 23, 2012 | 12:49 PM
seymore4's Avatar
m56
No need for an Fcon, especially since only a handful of people can even tune them.
Check your spark plugs, NGK LFR6AIX-11 are awesome, 1 step colder than stock.
Look up Osiris by Uprev.
Old Jun 23, 2012 | 12:58 PM
seymore4's Avatar
m56
An Osiris reflash will allow you to reprogram your fuel tables like this:
As well as remove the WOT restriction, set the rev/speed limiters, timing, disable codes, etc.
PM me any specific questions you may have
Old Jun 24, 2012 | 12:15 AM
Sparda1123's Avatar
Also if you were on the fence line about getting a tune, i got mine and its NIGHT AND DAY difference. Im also available on here if you have questions.
Old Jun 24, 2012 | 01:21 AM
N8digity's Avatar
I had planned on gettin an uprev tune once I had all the bolt on mods done them go from there. I was wondering of there was anything I could do in the mean time to some what eliminate that issue. Like an adjustable fuel pressure regulator or a wide band a/f gage to see if it's running lean or rich. I'm getting ready to order the mrev2 an iso thermal spacer set Friday and maybe the art pipes if I have enough.
Old Jun 24, 2012 | 01:32 AM
seymore4's Avatar
m56
If they heard detonation that means that its running lean... trust me Osiris will do wonders for you, even more than any of those other mods. You can always adjust it later on when you get more mods
Old Jun 24, 2012 | 01:48 AM
N8digity's Avatar
So do the Osiris tune the bolt on the planned mods and have a retune would be better then doing the mods then getting the tune. My base dyno was 248 whp and 218 trq. How much would it change those numbers with a tune ?
SoCalTed
Forced Induction
21
Aug 5, 2005 01:25 AM
