Help..CEL code P0057 HO2S heater control circuit low(bank2 sensor2)
Old Aug 31, 2012 | 10:20 PM
needforspeed's Avatar
I need help to find out is this a upstream or downstream issue. If it's upstream issue which o2 sensors do I need to look(near)?And it's downstream issue I guess o2 sensors near rear exhaulst pipe? Any input will be appreciated, thanks
Old Aug 31, 2012 | 11:15 PM
Dr. Ephil's Avatar
Haynes manual lists upstream sensors as 1/1 and 2/1, downstream are 1/2 and 2/2. I'm not positive but I believe bank two is the passenger side so check the o2 sensor on the passenger side cat. If it's bad it's a good idea to change the o2 sensor in the other bank at as well.
The best thing to do is get pipes and turn the rear o2 sensors off so you never have to worry about another cel from them.
Old Aug 31, 2012 | 11:51 PM
Thank you for the input. So, Bank2=passenger side and sensor2=front o2sensor near the cat area?
Old Sep 1, 2012 | 12:54 AM
Dr. Ephil's Avatar
You're welcome for my help, with the info I gave you and a little researching on your own you can easily find out for sure which bank is which and what o2 sensor needs to be replaced.
Old Sep 3, 2012 | 10:05 PM
Which is better sensor for its bucks? Bosch or Denso?
Thanks
Hasanbaloch
Feb 29, 2024 08:45 PM
Muski_G
Dec 1, 2023 11:11 AM
Detailed Image
Aug 17, 2015 02:45 PM
Detailed Image
Jul 29, 2015 08:42 AM
KevinnnVo
Jul 28, 2015 06:29 PM
