running rich
running rich
so my car is running extremly rich the exhaust tips are literally a powdery black have no idea wjat the hell it could be ses light is on checked the codes cam positioning censors amd crank censor is what its giving me could that be causing the problem?
What mods do you have? Naturally our cars runs slightly rich and seem to produce good amount of carbon if modded in some vehicles. Our ecu's will adapt to engine conditions but weird that it makes it run rich. Figured it throw it in limp mode. I'd go ahead and work off those sensors then see if its better. Have u always had the problem?
you are going to see a little more of the black carbon in the exhaust then without any cats on. i see this on my car even with high flow cats on. it might actually have more to do with that then the sensors at all. however if throwing the cam sensors and crank sensor code definately get those worked on as well
Thebaws11
Jul 2, 2021 11:36 AM
Thebaws11
Nov 30, 2016 12:54 PM
n2fooz
Sep 4, 2015 07:46 PM
