Thermostat code again!
Old Dec 18, 2012 | 02:00 PM
evan2k's Avatar
So i got the p0128 something code and i replaced the thermostat on my 2003 g35 coupe. I drive for about 200 miles and the light comes back on. I check the code again and its the same code for the thermostat. So my only next idea is that it could be the sensors? has anyone run into this problem yet, so i don't waste money on a sensor if its an easy flush or fix? THANKS!
Old Jan 30, 2014 | 07:15 PM
aurum0duck's Avatar
any follow up
Old Feb 27, 2014 | 04:54 PM
BH818's Avatar
Possible causes
- Leaking or stuck open thermostat
- Low engine coolant level
- Insufficient warm up time
- Faulty engine coolant temperature sensor
- Engine coolant temperature sensor harness is open or shorted
- Engine coolant temperature sensor circuit poor electrical connection
http://engine-codes.com/p0128_2003_infiniti_g35.html
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
KallDay86
Jan 8, 2016 12:42 AM
Jay123
Sep 28, 2015 08:42 PM
Detailed Image
Sep 28, 2015 07:04 AM
vamarris
Sep 26, 2015 12:56 PM
