VDC, SLIP and ABS, and no brake lights!!
Old Mar 5, 2013 | 09:38 PM
gustavog35's Avatar
hello people... I'm having some issues here with my car...
I just noticed my stop lights are not working, checked the fuse and it was fine, and the VCD OFF, SLIP and ABS lights come on... my brake pads are godo, bearings are good, oil levels are good... the thing is I used my multimeter to see if there was power in the brake pedal switch but there was none... so I replaced it... thinking the problem was solved, I didn't put them back together to the pedal, pressed both switches and nothing happened, pressed the brake pedal by itself and lights come back on... and still no power in the brake pedal switch... I honestly don't know what else to do...
Old Mar 6, 2013 | 10:29 PM
gustavog35's Avatar
just leting the 29 people interested in this thread... the problem was solved... it was a torn cable that got torn off the harness that gave power to the pedal switch... that's why there was no power...
Old Aug 11, 2019 | 08:59 PM
cuzin.danny's Avatar
INFINITI G35 Coupe 6MT w/Brembo's
Do you know which wire it was from the harness?
Mry
Mar 3, 2023 01:03 AM
mike730
Jan 12, 2018 04:25 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
Lsantana757
Jul 20, 2015 09:08 AM
