2006 G35X Drivers side door not working - HELP!!!
Old Jun 30, 2013 | 02:01 PM
merc2112's Avatar
Exclamation 2006 G35X Drivers side door not working - HELP!!!
So I came out of the store today and unlocked my door with the keyfob at the exact same time that I was pulling the handle to open it (yes stupid I know) -- when i pulled the handle nothing happpened. I tried to unlock the door again (by fob and maually using the key) and still was unable to open the door. I knew at this point something was seriously wrong so I climbed through the passengers side and tried to open from the inside -- still no dice.
I know that I must remove the door panel to inspect the mechinism, but I am in a catch-22 here because the door will not open. Anyone out there know how to deal with this? Am I going to have to call a lock smith to open the door?
Old Jun 30, 2013 | 02:28 PM
SergeantRed's Avatar
Always start basic checking fuses and other simple possibilities etc before jumping to conclusions. In the long run if you can't open the door you can't inspect the door wires/mechanism.... Silly as it sounds try disconnecting your battery ground for a minute and reconnecting..
Old Jun 30, 2013 | 03:59 PM
merc2112's Avatar
Thanks for the suggestion -- I tried that and it did not work. I ended up calling my roadside assistance and they sent out a locksmith. The locksmith popped the door and it reset the mechanism -- it must have been jammed.
Thanks again for the help.
mbe093
Lights
Oct 2, 2016 11:09 PM
Ludz
Lights
Mar 28, 2016 02:06 AM
R350k5
Oct 1, 2015 08:41 PM
emorehs
Jul 17, 2015 09:45 AM
attarday
Jul 15, 2015 04:03 PM
