Fuel Gauge/Fuel Sender Question
Old Sep 14, 2013 | 06:32 PM
DFWTXG35's Avatar
My fuel gauge on my 2005 G35 has recently started reading more fuel than what is in the tank. At fill-up, the gauge goes well above FULL and when the tank should be empty, it still reads around 1/2. Any ideas on how I can fix this?
Old Sep 17, 2013 | 02:01 AM
05_SkylineSedan's Avatar
20 Year Member
There is a way to clean the senders (search for that thread) but I replaced both units on our '05 which had a similar problem. I figured if I was going to go to the trouble of pulling them out of the tank to clean them I might as well just replace them (and the special blue gaskets). I'm pretty good with electrical but never work with raw gasoline - messy business! Don't know if I'd attempt it again. Ha!
Old Sep 17, 2013 | 07:41 AM
DFWTXG35's Avatar
Thanks! I'm not sure if my DIY skills want to attempt the cleaning or replacement of the fuel sensors. Seems like with others identifying with fuel gauge accuracy there should be a recall.
junon
Jan 14, 2023 09:37 PM
ara777
Aug 15, 2018 04:11 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
