Car shakes on idle and low rpm's
Old Sep 27, 2013 | 02:22 AM
Chrstian17's Avatar
Okay so I just started having issues with my car, out of nowhere at a light my car started shaking and I noticed that my rpm's started dropping. This continued to happen on red lights and while in Park. When I approached red lights I put the car in Neutral and kept the revs slightly above 1k and the car wouldn't shake. Once I got home I put the car in park and it took about 5 seconds for it to start shaking again. Also the start up is kind of rough. What could be my problem? Kind of a noob with the mechanical aspect.
CAR SPECS......
04 g35 coupe
AT
148xxx miles
Old Sep 27, 2013 | 09:27 AM
Urbanengineer's Avatar
Motordyne throttle body reset procedure. Idle air reset.
Old Sep 27, 2013 | 09:28 AM
Motordyne throttle body reset procedure. Idle reset. Do these two tests per the last page of this document.
http://www.motordyneengineering.com/manual.pdf
Old Sep 27, 2013 | 10:03 AM
Chrstian17's Avatar
What exactly do I do for the throttle body reset??
Old Sep 27, 2013 | 10:32 AM
Seriously? Re-read my post.
Old Sep 27, 2013 | 10:44 AM
Chrstian17's Avatar
I know but what does it mean when it says, make sure the throttle valve moves during these 10 seconds by confirming operating sound.
Old Sep 27, 2013 | 11:34 AM
You will hear a whine, and eventually a snap if/when the TB closes. This is not a loud snap... Rather subtle.
You could also take off the intake tube and check the TB for dirt or other clutter. Mine was caked in dirt when I checked it.
Jusseth
Sep 13, 2020 12:25 PM
ghost_g35
Aug 7, 2015 10:31 AM
Rehman2009
Jul 27, 2015 03:23 AM
ClwMike
Jul 23, 2015 12:55 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
