Headlight lens switch (foggy, Scratched, lens)
Old Oct 28, 2013 | 09:25 PM
Carmelo's Avatar
I have a 2003 G35 sedan
My headlight lenses are scratched and fogged up,
I've tried EVERYTHING!!! nothing seems to work
I was wondering, can I buy some cheap (non xenon) headlamps from ebay ($120 for the pair) and can i simply swap the lenses to my oem headlamps?
Is this possible?
I tried searching and nothing pops up.. PLEASE help!!!
Old Oct 28, 2013 | 09:30 PM
Urbanengineer's Avatar
The Ballast can be swapped, you can find a clean pair here on driver of 03-04 headlights.
Also, have you tried wet-sanding your lights? You would be amazed how well this makes things turn out!
Old Oct 28, 2013 | 09:39 PM
Carmelo's Avatar
The ballasts are working good, the lenses are done! lol
I've tried wet sanding, all of the products to clean lenses, I've tried it all!!
I was hoping It would be possible to just swap the lenses lol
the xenon lights are expensive!! and i just need the lenses
Old Oct 28, 2013 | 09:42 PM
So is the issue that they will never get clear again? It could also be on the inside!
Old Oct 28, 2013 | 09:45 PM
Carmelo's Avatar
pretty much!!
and people have told me I can't clean the inside, it'll ruin the lens more
? idk
Old Oct 28, 2013 | 10:30 PM
Its true but wtf it is done haha.
Google search that and see if it will work!
Old Oct 29, 2013 | 10:47 AM
vashawn's Avatar
Originally Posted by Carmelo
pretty much!!
? idk
Why would the inside get ruined?
Isnt the inside/outside the same material!!
What the hell i would do the inside if it s already ruined! And if it gets worst just wrap the headlights
Old Oct 29, 2013 | 11:26 AM
WILLIE BEANS's Avatar
hmmm, wonder if thatl work .?
Old Nov 4, 2013 | 08:20 PM
Carmelo's Avatar
how do I take the lens apart from the light ?
Old Nov 4, 2013 | 09:19 PM
jcseven7's Avatar
Do not touch the inside of the lens. You will ruin it. If your lenses are "foggy," or oxidized, polish them. If they are really bad wets sand with 2000 grit, then polish.
Old Nov 5, 2013 | 12:08 AM
Carmelo's Avatar
anything in particular you recommend for the polishing part?
Old Nov 5, 2013 | 12:10 AM
hurleyguys's Avatar
what every you would use on your paint, use on your lens.
cmesidewayz
Sep 29, 2015 09:28 PM
neight
Interior
Sep 21, 2015 05:35 PM
johnadlertech
Lights
Sep 4, 2015 12:35 PM
