Ignition stuck in lock position
Old Nov 4, 2013 | 04:24 PM
dnagel10's Avatar
Hi guys
I went to start my car this morning and the key wouldn't turn, the ignition is stuck in the lock position and won't budge. I tried wiggling the steering wheel and turning the ignition a bunch of times without any luck. I also unhooked the battery for a few moments and reattached it. The battery is only a year old.
Has anyone had this problem before or know what the issue could be?
Its a 2004 Infiniti g35 coupe
Thanks
Old Nov 7, 2013 | 12:33 PM
trevtrevs14's Avatar
Is your car automatic?
Old Nov 7, 2013 | 09:35 PM
Urbanengineer's Avatar
Have you recently done an install or messed around with your stereo head unit? There is a plug under the shifter that is unlikely to slide out.
Also could be you left the car in neutral .
Old Feb 11, 2014 | 10:28 PM
brohde1216's Avatar
Originally Posted by dnagel10
Hi guys
Thanks
hi i was just wondering if you gotten that fixed? my 03 g35 sedan is doing the same thing
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
douglas555
Sep 10, 2015 04:48 PM
