Lighting problem
Lighting problem
When I drive and go over a bump, or sometimes randomly, the passenger side HID bulb goes off... when I turn my lights off and back on it comes back on and works perfectly fine.. Could this be the instillation of the bulb, wiring or the ballast gone bad? those are the only problems I could really think of.. has anyone gone through this before and if so what was the solution?
My back taillight on the driver side within the circle has also burnt out a couple bulbs, is there a way to replace/fix this problem?
Did a little research and found a solution for the taillights.. still couldn't find anything relevant as to why my HID's keep turning off...
Found this video really helpful for replacing my taillight bulbs
