Window motor
Old Feb 24, 2014 | 09:22 PM
Bwoyalex's Avatar
Window motor
Quick question. My driver side window will not stay up, everytime I put it up, it pulls back down almost to the half mark, is that a window motor problem or?
Old Feb 24, 2014 | 10:46 PM
Urbanengineer's Avatar
What happened is your window motor forgot where the top of the frame is. You have to take off the door panel (three screws, two in that thing you use to swing the door shut, one in the door handle (inside) area).
You can pop the door panel loose from the bottom up. The panel itself comes out once all the pop rivets are loose and you pull up.
From there there is a little button hidden under a black sticker in the center of the door. You open your door, lower the window....
rest can be found on infinitihelp.com
Good Luck!
Old Feb 25, 2014 | 12:37 AM
Bwoyalex's Avatar
Thank you very much! I'll try this tomorrow an hope it works
Dallsinghjr1
Sep 17, 2023 11:25 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
