Is it possible to swap. My black non rev up injectors with the hr green ones?
I would also like to kbow this as well. As far as searching goes the vq37hr motor uses 330cc and the vq35de is 300cc. Of course I believe this is at 55 psi. I could be wrong cause i gave up on the idea after my tuner says its unnecessary for na. Hr would have a high flow rate and a compensation map would be required if stock or you would be running rich. So based on some findings I do believe the vq35hr share the same injector as the vq37hr. If I am wrong please disregard this post.
