Vibration SOUND coming from what seems like front wheels
03 coupe. There is the SOUND of a vibration only, sort of like a fluttering, coming from what seems like the front passenger tire. No steering wheel shake under acceleration, at speed, or under braking.
Any idea? would a simple balancing be all i need?
any input would be appreciated ;]
Do you know what to look for if you're tires aren't wearing correctly? Even if you do take your G to an independent brake/alignment shop, they'll be able to correct whatever is causing the noise you describe.
Gary
Gary
I had a similar vibration many years ago, it turned out to be a steel belt in my tire which had slipped.
The entire tread came off at 45mph, ripped up my fender well, tore off side molding and left some nasty scratches.
Put your spare on & drive it. If the vibration is gone, then it's your tire. If not a shop would be able to tell you what it is.
Shop said it's the wheel bearing. I had a wheel bearing going on my old BMW and the sound was way different. I'm just having them balance it and I'll see if it fixes the issue.
rezendvous420
May 31, 2020 01:26 PM
