Carbon fiber diffuser
I purchased a ionicdynamics cb diffuser locally for a g35 coupe. The owner didnt have the hardware but did have the instructions to install it. I was wondering if you guys know what bolts, or screws I should use. As well as the 3M double sided tape. Thanks
It uses 2 screws at the license plate area & about 4-6 push in clips on the under side, same as the clips used to hold in the fender liners & grill. The predrilled holes on mine were off as it didn't fit flush. Had to drill new holes.
Ok that's what I'll do
Aha, I should have mentioned my diffuser is from Mr. Wong at Statik, I was unaware IONIC's came with tape installed.
