04 g35 coupe headlight problems
Old Jun 18, 2014 | 12:15 AM
Jarboe2012's Avatar
My passenger side headlight bulb flickers on and off. I think there may be a short in the wiring somewhere. Some times it's on and sometimes it's off. It's the hid bulb in the top part of the head light. Has anyone else had this problem?
Old Jun 19, 2014 | 06:28 PM
dreloc's Avatar
Do you have an OEM hid bulb in there? Could be the ballast about to go out
Old Jun 19, 2014 | 06:38 PM
ScraggleRock's Avatar
Its probably the ballast. Switch it with the driver side headlight ballast and see if the other one flickers. If not, then check the bulb the same way.
Old Jun 23, 2014 | 09:48 PM
Jarboe2012's Avatar
I will try switching the ballast from side to side. As far as I know it is the oem hid bulb, I haven't had the car but for about a month.
Old Jun 23, 2014 | 09:53 PM
WhosUrBuddiee's Avatar
Most likely a bad ballast.
Jusseth
Sep 13, 2020 12:25 PM
bTanz
Oct 15, 2015 02:31 PM
wonderizm
Sep 24, 2015 03:09 AM
attarday
Jul 15, 2015 04:03 PM
