passanger axle replacement
Old Nov 7, 2014 | 11:17 AM
eddosi's Avatar
Can someone help me on replacung a front passanger axle
Old Nov 10, 2014 | 11:37 AM
Mustang5L5's Avatar
https://g35driver.com/forums/drivetr...ot-change.html
Old Nov 10, 2014 | 06:07 PM
eddosi's Avatar
Thankyou mustang.i tried to loosen the ball joint on the lower ball joint to get the hub loose so i can manuver it but ball joint scre was spinning so i gave up lol
Old Nov 12, 2014 | 09:11 AM
Mustang5L5's Avatar
Use a C-clamp and clamp the lower arm to the spindle tighter and then try to remove it.
I use that method a few times in this write-up on removing wheel bearings
https://g35driver.com/forums/brakes-...-bearings.html
jsimonk
Dec 22, 2023 03:49 PM
11bEMT
May 27, 2022 03:13 PM
miata007
Aug 17, 2015 04:36 PM
wuppiedog
Aug 7, 2015 11:16 AM
attarday
Jul 15, 2015 04:03 PM
