IPDM fuse box question.
Old Feb 14, 2015 | 07:12 PM
stroked Luxury's Avatar
My IPDM has shorted out, causing only the remaining fuses for fail safe mode to work. Cooling fans cut on in the ON position. I am wondering if the IPDM from a 05 sedan will work on the 2006 coupe. Based on my visual inspection. They look exactly the same for all the fuses and relays. If anyone knows if the Two parts are interchangeable please chime in. If it helps, it is the tan colored IPDM not the older black one.
Picture Share
Feb 4, 2018 12:41 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
prinny
Nov 22, 2015 11:07 PM
Learned Hand
Oct 1, 2015 09:02 AM
