White steam coming from engine after radiator change and install.
Old Feb 24, 2015 | 02:02 AM
dmoua's Avatar
Unhappy White steam coming from engine after radiator change and install.
I'm a noob with cars but I'm trying to learn as I go. Facebook G35 Driver group isn't very helpful with all the hate.. But anyways I have an 03 coupe and changed my radiator from OEM to a 2 row aluminum because of a crack in the plastic frame. I just finished burping the cooling system, but noticed at a stop or idle white steam comes out.
I didn't change the hoses or thermostat either..
Could the steam be from my water pump? Someone on Facebook confidently said it was my head gasket. I am going to take my car the shop, but still what do you guys think could be the problem?
Old Feb 24, 2015 | 05:32 AM
ScraggleRock's Avatar
Haha, man, fukc FB.
Nah, bro, a head gasket wouldn't be shooting steam outside of the motor, it would be leaking into the motor.
Few things:
-Did you replace the rad cap?
-Did you change the hose clamps to screw type?
-are you getting heat in the cab when you put the heater on full blast?
Old Feb 24, 2015 | 09:33 AM
herrschaft's Avatar
Pop the hood, it should be easy to find the leak.
Old Feb 24, 2015 | 11:20 AM
gary c's Avatar
Yea, you need to pop the hood to find the leak! Likely a hose clamp you forgot to tighten...Gary
Old Feb 24, 2015 | 02:31 PM
dmoua's Avatar
Originally Posted by ScraggleRock
Haha, man, fukc FB.
Few things:
Haha. Oh okay hearing that makes everything sound so much better. The new radiator came with it's own rad cap but I didn't change the hoses or thermostat. My heater works perfectly as well.
I checked my radiator fluid this morning and it was full but my reservoir had no coolant at all so I had to refill it. The cap on the reservoir tank does have a huge crack on it that opens up if I screw it on so air is exposed into the tank. Maybe that's a problem too? I'm going to pick up a new cap today.
Old Feb 24, 2015 | 02:32 PM
dmoua's Avatar
Okay. I'll be test driving later today to check for any leaks. Hopefully the coolant spilt during burping has dried. Thanks!
Old Feb 24, 2015 | 02:34 PM
dmoua's Avatar
Okay thank you! There were no leaks at all during burping. But I'll still double check hoses and clamps.
Old Feb 24, 2015 | 03:18 PM
^haha that's exactly what it is.
yassy
Aug 3, 2015 12:24 AM
joedaddy1
Jul 28, 2015 02:58 PM
newg37
Jul 26, 2015 09:32 AM
realtalk21
Jul 20, 2015 09:07 AM
