Startup Issue and CEL (check engine light)
Old Mar 22, 2015 | 08:43 PM
codename47's Avatar
Hi all,
I am new to this forum
I have a V35 Coupe ( In Australia) and have this CEL on the dash
When I start the car, car dies if I don't accelerate. But If I push the pedal a bit it starts up normally. Do you think this could be related to CEL ?
I've run auto diganostic it threw few codes up
P0037 0102 etc
I have cleaned the MAF using carby cleaner and let it dry no luck
any one had these issues?
thanks in advance
Old Mar 24, 2015 | 07:58 PM
codename47's Avatar
Never mind
got it fixed
it was o2 sensor on bank 1 ( second one)
Old Apr 5, 2015 | 04:25 PM
h20poloman's Avatar
good to know you found your problem. I would advise against carb cleaner in the maf sensor.
They sell CRC cleaner brand for maf sensors that do no harm the actual sensor something to keep in mind.
Regards,
Leo
Old Apr 5, 2015 | 10:17 PM
andrewvk's Avatar
the o2 sensor wont cause the starting issue you were describing.
Old Apr 6, 2015 | 09:11 AM
h20poloman's Avatar
I second that. But hey if he says its fixed. The o2 sensor works to adjust the air to fuel ratio. Thus a faulty 02 sensor will cause the engine to run rich as fail safe. that is bank 1 or bank 2 only the number 1 sensor on each bank does this . the secondary is there just to check for catalytic performance, or if they are simply just there.
the p0102 is related to unaccounted air coming into combustion. usually intake leaks, plenum leaks, and moust commonly maf sensor issues. this would explain his issues. If anything maybe the carb cleaner worked on the MAF. they can get dirty from not changing the air filter at reasonable time intervals.
This will cause issues with idle such as what you are having. If you forget to plug it in or simply unplug it you will see what I mean.
p0102
- Faulty mass air flow sensor
- Intake air leaks
- Dirty mass air flow sensor
- Dirty mass air filter
- Mass air flow sensor harness is open or shorted
- Mass air flow sensor circuit poor electrical connection
Muski_G
Dec 1, 2023 11:11 AM
ClwMike
Jul 23, 2015 12:55 PM
Lsantana757
Jul 20, 2015 09:08 AM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
