G35 coupe shakes when idle
Received 2,456 Likes
on
Coupe 6MT Premium RAS
Get it up on a lift, start the motor, look for anything moving that SHOULDNT be moving. If you're having a hard time finding a lift for a reasonable price you can usually work out a deal with a local lube shop that has a pit. Sometimes it's as simple as a broken exhaust hanger, sometimes it's a worn bushing, sometimes it's a broken motor/transmission mount. Get someone to sit in your vehicle and shift from park-reverse-drive-reverse-park-rinse-repeat, it should be pretty obvious what's broken because nothing should be moving at all when you do that.
Does it shake in park or only while in gear? Usually if it shakes only while in gear then you're looking for a worn/broken engine or transmission mount.
on
Without actually seeing the cat it's hard to say, you can remove it, look inside, if the honeycomb looking grid inside has melted spots on it then yes it needs to be replaced but I would get a second opinion unless you have a lot of faith that this mechanic to not screw you over replacing stuff that isn't actually tested.
You can always ask to have him show you WHY the cat is bad, there will be physical evidence, don't rely on "magical gut feelings" when it comes to replacing parts on a car, ALWAYS ask to have them show you the details, a reputable mechanic will hide nothing.
on
Hey Certified, any chance you got this issue resolved? I'm having a similar issue with my 03 G coupe and I think it's the Cat as well... When you're at an idle and it shakes, does it kinda feel like someone lightly tapped your car from behind? That's what it feels like to me. And once your parked and turn the car off, is there a tapping noise from your exhaust near the Cat? Mine does and that's what leads me to believe it's the Cat... Please let me know if it's the same and if you got it resolved.
