How hot does your ride run?
Get it checked
See the cooling section in the FSM for your vehicle
Thermostat
Radiator cap
Water Pump
Coolent
Fans
Good luck
Telcoman
Mine usually sits one notch below mid-gauge. Yours looks like it's one notch above the mid-point.
Does yours move, or pretty much stay the same? You can verify actual coolant temps with an OBD2 scanner and an app on your phone. Mine usually runs between 180-190 degrees, might get up to 195 when driving hard.
the3kgt2
Engine - Electrical
Mar 27, 2016 06:33 PM
