need help with splashshield placement please
Old Jul 30, 2016 | 02:32 PM
05_SkylineSedan's Avatar
20 Year Member
OK, the coupe manuals don't show a part like that until '08. Doesn't mean your '04 doesn't have it, just the manuals are no help... Here's the shot from the '08 book:
Attached Thumbnails need help with splashshield placement please-nosplash.jpg
Old Jul 30, 2016 | 02:50 PM
saywat?'s Avatar
On the g37 it sits on top of the fender liner. I recently replace the passenger side. 2 pins on top and 2 bolts on bottom attached to the engine guard I believe. Might be similar to the g35
Old Jul 30, 2016 | 03:35 PM
zenkig's Avatar
There maybe? Through that hole in the steel
Old Jul 30, 2016 | 03:47 PM
saywat?'s Avatar
I see 2 holes u can try. The one free one and the one with the push pin. Remove it and sit the piece over it
Old Jul 31, 2016 | 01:02 AM
20 Year Member
Still unclear to me but that's where it supposedly goes... Here's the "detail" from the '08 illustration, flipped. Doesn't quite line up with the holes you have but notice it is partially tucked behind the fender liner...
Attached Thumbnails need help with splashshield placement please-pieceflipped.jpg
Old Jul 31, 2016 | 01:08 AM
saywat?'s Avatar
Imo that detail is insignificant I didn't do that it was jus easier to put it on top.
Old Jul 31, 2016 | 10:32 AM
zenkig's Avatar
Yeah I gotta just pull the main shield and figure this out. I couldn't see one on the left, by turning the wheels full lock each way. I'll try harder when I do my oil sometime this week. Maybe it goes in the bumber to cover the corner lights harness or something, idk. My guess is even though it's part of the front fender fitting on the parts list, it mounts into a different assembly though if that makes sense. Like doesn't clip into the fender liner.
Old Jul 31, 2016 | 10:38 AM
zenkig's Avatar
Must sit above this piece where you can't see unless you remove it. Like up in the bumper .
Old Jul 31, 2016 | 02:59 PM
saywat?'s Avatar
No I can def say it doesn't
Old Aug 7, 2016 | 01:17 PM
zenkig's Avatar
figured it out
I got it, it was easy with the engine splash shield off. The cut out goes around the sway bar. Done and done. From what I can tell only the passenger side has one unless my driver side is missing
Old Aug 8, 2016 | 03:42 AM
20 Year Member
Wow, nicely done! I could NOT find that piece anywhere in the FSM... Glad you found the spot for it.
Old Aug 8, 2016 | 06:33 AM
zenkig's Avatar
Thanks, what a pain haha. I was trying to put in one from outside with the wheel full lock. It will only go on from underneath with the big shield off. Glad that's over. Thanks fo going outta the way to help. I'll try to pay it foward
zcherub
Jul 26, 2016 10:54 PM
G35NBOOB
Jul 22, 2016 02:48 PM
philbegas
Jul 18, 2016 05:47 PM
