Emergency! Need help ASAP!
Old May 7, 2017 | 02:57 AM
Grezza's Avatar
I got off of work today, park my car and went into my home. I hung out for about an hour then took a shower and was getting ready to go out and meet a friend. When I went down to the street to unlock my car with my keyless entry, nothing happened. I got my back up keyless entry and same thing. It won't unlock, lock, alarm or anything! I was able manually unlock my car, but the engine will not start at all! I tried swapping batteries in keyless entries to no avail. It's like my car is under a security lockdown or something and I am freaking out as it is now sunday and the Infiniti dealership will he closed. I tried the reset tip found here:
https://g35driver.com/forums/general-tech-questions/381867-2006-g35-keyless-problem.html
to no avail. There's no lights in dash, and the manual trunk release won't even work! I know my starter, battery and alternator are all good... What do I do? Is the dealer the only one that can fix this?? I'm freaking out big time since this happened completely at random.
Old May 7, 2017 | 11:21 AM
telcoman's Avatar
Veteran: Army
Remain calm.
Do some logical troubleshooting
How old is your battery?
How do you know your battery is good?
Did you try jumper cables?
Test all six of your battery cells with a battery hydrometer.
Are the battery cables tight and free of corrosion?
After jump starting
Measure your alternator output voltage with a multimeter
Telcoman
Old May 7, 2017 | 12:17 PM
gary c's Avatar
I don't recall ever hearing someone with a dead battery having zero response from everything electronic! Sounds more like a cable issue, where there is no contact! This is the reason I've had the Auto Club for emergency backup since my radiator exploded on my previous car going to Vegas!
Gary
Old May 7, 2017 | 02:02 PM
telcoman's Avatar
Veteran: Army
Gary
IMHO everyone should have AAA for any emergencies. They will provide up to 200 miles of free towing on a flatbed truck if necessary and provide a battery replacement as well as emergency gas should that ever become necessary. Also on a breakdown on certain toll roads you must use a tow service under contract that will only tow you to the nearest exit. You then must get another tow service. With a AAA membership all of that is covered.
Telcoman
Old May 7, 2017 | 11:17 PM
Grezza's Avatar
Update: soooooo, it was the battery. Tried a jump pack and it didn't have enough so my brother gave me a jump. We then removed some speaker wire that the previous owner had running through from near the battery to the trunk, in case it was somehow draining it. Unfortunately, after it sat for 20 minutes, it wouldn't start again - everything completely dead, including the keyless entry. Got another jump and replaced the battery. All good so far, however I'm going to have a friend that works for Infiniti check the alternator, make sure there's no voltage drop and check for any parasitic drain (no interior or exterior lights or anything were left on when the battery died). He's replacing the ac compressor anyway. Took her for a celebratory bath after 😁
Old May 8, 2017 | 12:03 AM
ScraggleRock's Avatar
Man, that thing would look so good if you got yer headlights restored.
Old May 8, 2017 | 12:13 AM
Urbanengineer's Avatar
Just like my old sedan .
