Passenger side switch not working
Old Mar 24, 2018 | 12:19 PM
Schenzel's Avatar
Its official. The car is haunted. I went outside to head out and the passenger window rolled down perfectly from the passenger switch. wouldn't roll back up tho. And only illuminated power from the switch when it was pressed down. Driver switch still did nothing. Door lock switch was working perfectly for a minute. Now it's dead again.
Old Mar 24, 2018 | 03:01 PM
telcoman's Avatar
Veteran: Army
Originally Posted by Schenzel
I have searched everywhere and I’m lost. I have an 06 G35x, up until this week it’s been great, until all of a sudden the passenger side window and the door lock switch on both sides don’t work. The switch on the passenger side isn’t illuminated nor does it click when I try to roll the window down. I have replaced the motor and switch a couple times with parts that i know are working. Could it really be the harness in the door is somehow throwing this off? All other windows work from the master switch and their respective switches, except for the passenger side
But have you looked in the FSM?
http://www.nicoclub.com/FSM/G35/Seda...5_Sedan/pg.pdf
You are most likely to have a missing/broken ground connection? (M30)
See pages PG-29, PG-30
Why are you not using a multi-meter to test instead of just throwing parts and guessing?
A $150 diagnostic fee at an Infiniti dealer might be a better solution for you if you don't possess the necessary electrical skills to properly troubleshoot the problem.
Just my $.02
Telcoman
Old Mar 24, 2018 | 05:16 PM
Schenzel's Avatar
Problem SOLVED. As I suspected it was in the driver door wiring harness. I just switched it out and now all windows work as they should. I suppose I should've mentioned prior that I had the same car available to me for parts that I needed so i wasn't really spending money but the gas to go get said parts....
Old Mar 24, 2018 | 05:19 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
That's interesting, I always figured the splice in the 12v and ground (white and black) wires took place near the BCM but what you're saying pretty much confirms that the splice takes place in the driver door harness.
Schenzel's Avatar
the passenger window doesn't move at all from driver side or passenger side switch. The same goes for the lock. Neither side will work. The key fob operates as it should and the doors lock and unlock from that. Just not the switch in the car
thank u for the wire wiring code, I checked the white wire on the driver side and it didn't show any power, which confirmed my suspicion.
Silver tiburon
424
Jul 19, 2022 03:26 AM
foreverdr1ft
Interior
Jan 6, 2017 11:45 AM
Kadeem Brown
Aug 23, 2016 02:21 PM
gsg
Jul 15, 2003 07:02 PM
BillR
Jun 7, 2003 09:44 AM
