Day of reckoning / dealing with my poor decisions!
Old Apr 24, 2018 | 01:05 PM
cswlightning's Avatar
The other day when I removed my rear camber kit I took a closer look at the rust I knew my car had... but this time I started poking around with a screwdriver inside the wheel well.... and broke through in several places.
When I bought it there was a little bubbling on the top arch, but nothing else visible - I figured I could drive it all winter and fix it in the spring when the weather got warmer without the rust completely killing my car.
It's gotten worse.... much worse. I fully expect the pinch weld to be destroyed under those side skirts although all the jack points and the rest of the undercarriage are relatively rust free.
I don't have the money for a professional repair, but I am prepared to undertake the task of taking off the side skirts, removing the rust, and doing whatever is necessary to keep the car on the road looking presentable for another 4-5 years....
Has anyone dealt with this sort of thing before and have any advice for me before I start? The procedure I intend to use (after research)
-Remove rust with sandpaper grinder and wire brush making sure to remove all rust
-Spray all metal with Rustoleum
-Use body panel glue to add more metal to wheel arches if neccissary, use Bondo to fix shape so it looks presentable - using a friend's G35 as reference
-In the area under the side skirts, I was planning on using body glue and seam sealer to attach sheet steel to keep it all together and prevent water from getting in, and just covering that steel in a couple coats Rustoleum.
Am I screwed?
Old Apr 24, 2018 | 03:16 PM
Pics would help... Doh!
njsfastestg
NorthEast
16
Oct 9, 2007 07:40 AM
skylinegtr276
Feb 24, 2004 08:47 PM
Future0wner
Sep 29, 2003 11:02 AM
sp1rider
Mar 20, 2003 09:54 AM
