Recently replaced Clockspring. Now car won’t start.
Old Aug 13, 2018 | 09:31 PM
Kuma's Avatar
Hello. I recently had my steering wheel clock spring replaced on my 2005 G35 coupe and now the car won’t turn on. It cranks but won’t turn over. The fans turn on when key is turned to the on position and the gear indicator is not displaying anything. It’s an automatic. Please help.
Old Aug 14, 2018 | 07:47 AM
LoSt180's Avatar
You did something wrong. Retrace your steps and verify everything is plugged back in. Battery should be disconnected when doing this.
Old Aug 14, 2018 | 08:16 AM
telcoman's Avatar
Veteran: Army
Originally Posted by Kuma
Hello. I recently had my steering wheel clock spring replaced on my 2005 G35 coupe ........
Why?
Telcoman
Old Aug 14, 2018 | 07:59 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The car will start without the steering wheel installed so it's not the clock spring causing the problem. You get an SRS airbag error with the steering wheel removed though.
What's the security indicator light doing when you turn the key to start.
The engine DOES NOT CRANK AT ALL correct? Or does it crank but fail to run?
Old Aug 14, 2018 | 08:01 PM
cleric670's Avatar
BANNED!!!
If it cranks but won't start it could be fuel pump, crank sensor, cam sensor.
If it won't crank it's probably NATS.
wade0731
Mar 12, 2017 10:33 AM
RemmyZero
Aug 22, 2015 11:38 AM
jaguar31
Jan 10, 2015 12:54 PM
TheloniousMonk
Jan 1, 2014 06:19 PM
G35 Owner
Oct 14, 2008 10:58 AM
