Leak found?
Old Oct 30, 2018 | 05:00 PM
johnwelby's Avatar
G35
Leak found?
Hello is this hole supposed to be covered up? It’s located behind the battery.
Old Oct 30, 2018 | 05:06 PM
johnwelby's Avatar
G35
This?
Old Oct 30, 2018 | 05:45 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I dont see a picture. Use the tools on the editor above where you type, click the landscape icon and upload the picture directly into the message body.
Old Oct 30, 2018 | 06:12 PM
johnwelby's Avatar
G35
this
Old Oct 30, 2018 | 07:00 PM
victor0206's Avatar
That’s where the cabin air comes in from. It’s supposed to be open. You can actually see your cabin air filter too from there if you take a peak!
Old Oct 30, 2018 | 08:49 PM
herrschaft's Avatar
Remove the cowling above it to get a closer look, looks like its leaking at the top.
Old Oct 31, 2018 | 12:03 AM
johnwelby's Avatar
G35
If water gets in there can that cause wet passenger seats?
Old Oct 31, 2018 | 08:00 AM
G2B35AGN's Avatar
Do you have a sunroof? Are your drains plugged with accumulated environmental debris? That's a common issue. Do a search. There are multiple threads and one in particular has good info on troubleshooting and how to clear the lines, with pics.
Old Nov 1, 2018 | 07:52 PM
herrschaft's Avatar
No. Where is the water coming from? The headliner is the only way the seat is going to get wet unless your windows were open.
lefizzet
Jan 1, 2012 03:50 AM
g35guy86
Mar 4, 2011 06:00 PM
aeroplane
Jul 12, 2010 05:45 AM
gtaco35
May 21, 2010 06:20 PM
