Oil Dipstick?
Old Jun 21, 2019 | 05:47 PM
WoodG35's Avatar
Bone stock G35, got everything but sirius radio. :(
Oil Dipstick?
I had a question about then oil dipstick, Does the dipstick go right into the engine block or should there be a tube from the engine that the dipstick goes into?
Mine gets stuck directly into the engine itself and it is very heard to get an accurate reading on the dipstick.
No matter how long you let the engine sit non-running or how many times you wipe the dipstick clean when you insert it and pull it back out the stick still comes out with oil everywhere on the dipstick and it's hard to tell where the level is on it.
Is it just me or my incompetence with this car or is this kind of an issue with them all?
Mind you, I am 53 and have owned 20+ some odd cars in my life and worked on them all along with probably a hundred others so I am not an idiot newb to cars. I just have not had such a problem with checking the oil level on a vehicle before....
Old Jun 21, 2019 | 06:26 PM
Hall Stevenson's Avatar
I have an '08 and it has a dipstick tube.
Old Jun 21, 2019 | 07:59 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The G35 has a really shitty dipstick tube, only check the oil on a cold engine that has not been started for the day. That's the ONLY way you will get an accurate legible reading.
Old Jun 24, 2019 | 03:04 PM
WoodG35's Avatar
ok, Thanks for the replies guys.
Does anyone know if a 2005 G35 has a dipstick tube or if the dipstick just slides into the block itself?
Old Jun 24, 2019 | 03:12 PM
cleric670's Avatar
BANNED!!!
It's more of a "guide", not a tube and it seals directly to the block. Here's the Nissan part number so you can see for yourself.
11150-AM61A
Old Jun 27, 2019 | 03:35 AM
WoodG35's Avatar
11150-AM61A
OK, Thank you. I have been wondering if I had something missing there.....guess I don't. Thanks again.
Old Oct 31, 2019 | 07:48 AM
chasracer's Avatar
It's just one of those things that you have to sorta work with - took me a few weeks to understand what was going on as the design of it allows it to pick up oil residue as it is being withdrawn or pushed into place. I have had my G for a long time now - 14 years - just a quirt of the car.
CKwik
Aug 7, 2004 08:27 PM
Andyl
Jun 25, 2004 11:01 AM
FrankieBallzzz
Jun 17, 2004 01:42 PM
chinee
Jun 7, 2004 02:46 AM
Ehrpower
Jan 8, 2004 01:39 PM
