03 G35 Sedan A/T Cont Fuse Constant Blowout
Old Aug 20, 2019 | 08:07 PM
YGNKnowledge's Avatar
Infiniti G35
My A/T Cont fuse keeps blowing Everytime I turn the key to the on position. It stopped blowing after I draiined the transmission pan but about 5 min after filling it back up it started to blow again. Only thing I changed on the car was the pressure control solenoid that Is on the valve body. I connected everything right and now the fuse blows Everytime I turn the key. Or the starter will click a few times then the fuse will blow.
Old Aug 20, 2019 | 09:43 PM
infinity35's Avatar
Infiniti g35 Coupe 3.5
Most likely it's being shorted out by something else in the electrical system. Check all your other fuses and relays, make sure they're all functioning properly. Most likely you have a blown fuse, relay or a shorted circuit somewhere. Does your car have any other electrical issues, even like a headlight that always goes out?
Old Aug 20, 2019 | 09:52 PM
Infiniti G35
I checked all grounds and they are good. All other fuses are good, lights and everything else are good. No other electrical issues just this at Cont Fuse and it's only when I turn the key it instantly pops. Didn't start until I changed the VB solenoid, a friend told me when he bolted the VB back on he forgot two bolts that go on it other than that nothing.
sas555
Dec 3, 2017 04:23 PM
korfak
Nov 23, 2015 02:14 PM
JJJEEEEETTT
Jul 6, 2011 06:18 PM
robgonzalez510
May 24, 2009 08:29 PM
