Help!!
Old Aug 25, 2019 | 08:47 PM
JamarcusOS's Avatar
infiniti g35 awd
Help!!
I have a 05 Infinity g35x sedan and I and having some trouble with it lately. My first problem was I had a bad battery ,so I replaced it . Then when I replaced that my check engine light came on and read camshaft position sensor a bank 2 . The guy at NAPA told me it was on the driver side so I replaced it . Then the code didn’t leave so I ended up replacing both. After I replaced both I went to get another diagnostic which read my crankshaft sensor now and still read camshaft sensor a bank 2 and and evaporative leak code also popped up . Then on my way home my car started jerking hard and my engine would lose power. Basically I would be driving and the engine seemingly dies but my rpm still revs up and the car shifting hard. My vdc and abs and check engine light are on now and I need to know where else to start.
Old Aug 25, 2019 | 10:59 PM
Scorpi0's Avatar
Always replace your crankshaft and camshaft sensors with original sensors!! These cars do not work well with aftermarket.
Old Aug 26, 2019 | 08:22 AM
JamarcusOS's Avatar
infiniti g35 awd
I have to get OEM from the dealer or do you know a website that has them?
Old Aug 26, 2019 | 10:38 AM
Scorpi0's Avatar
U can shop around but the best price I found was at NissanPartsPlus.com. Dealer will most likely charge u a lot more.
KiddBrains
Jun 7, 2008 09:29 AM
apt2189
Jul 14, 2007 07:39 PM
-MofoLife-
Aug 14, 2006 03:27 PM
Soju
Jun 1, 2006 01:43 AM
lamrnd03
Dec 3, 2003 09:36 PM
