03 G35 Sedan U1001 and U1000 code please help.
no crank no start just click Please help I change the main line pressure control solenoid in the valve body, and after putting the valve body back in I made sure all connectors and everything we're in the right places but now. My 10a AT Cont Fuse blows when I turn the ignition to the on position and I get a u1001 and u1000 code. The code only shows up when the fuse blows and when the fuse doesn't blow there are no check engine codes at all.
I don't think so. I know I shouldn't do it but I put a 20a fuse in where the 10a is for AT Cont and no check at light comes or or anything at all and it'll try and turn over. The battery I have in the car is a 35 type but it is smaller than the original battery that I had in the car at first so I thought it could've been that but it won't even star with a jumpstart.
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
I was thinking the same thing. I did that once on a RE4 trans and grounded 1 solenoid out.
Those codes finally went away my battery was to small. Now the only code im getting is p0745 the line pressure control solenoid. I changed this once before because I first had that code I might've changed the solenoid to another bad one. I will have to do it again and the new solenoid I got measured 13-14 ohms
YGNKnowledge
Aug 20, 2019 09:52 PM
jjuriga
Aug 11, 2017 12:13 PM
