Odb code p1111
Old Dec 17, 2019 | 01:40 AM
Jin Pummell's Avatar
G35 coupe
Odb code p1111
Pulling p1111 code after chaging passenger valve cover gasket and cleaning throttle body. So far I replaced vvt solenoid. Dont know what else to do. Please help.
Old Dec 17, 2019 | 09:32 AM
depmike38's Avatar
5 Year Member
g35X 4dr sedan
Check the connector going to that solenoid and be sure a pin didn't get pushed over or a wire break. All I can think of if nothing else was disconnected. Also, could a wire have gotten pinched under the valve cover?
Old Dec 17, 2019 | 12:20 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
That's not a valid code for the G35, are you sure you didn't mean P0011 ?
You should use a different scanner if it's actually showing P1111.
KG II
Jun 3, 2019 01:01 PM
irvgotti
Aug 6, 2011 06:09 PM
canecorso1985
Aug 12, 2010 05:24 PM
