Gauge cluster issue (odometer)
Old Apr 21, 2020 | 05:30 PM
Michael Skwarek's Avatar
G35 SEDAN
So, I picked up a molested g35 to daily and restore the body, but im having random issues with the car...for one being the odometer having flickering numbers. When the car is cold it reads 197xxxkm
When it hits operating temp the 1 and the 9 turn into a partial 1 and the 9 becomes a 3.
anybody else have similar odometer issues?
***The trunk release has been rewired and out of nowhere it stopped working, I'm assuming a poor ground, or knicked wire is to blame***
Old Apr 21, 2020 | 07:53 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Both are fairly common points of failure on these vehicles. The trunk wires break at the flexible loom to the trunk. The instrument cluster has components that peel off due to expansion/contraction from weather.
Probably need a new instrument cluster and some soldered wires to the trunk. Troubleshoot before replacing, the cluster can he put in diagnostic mode to see if things are an external or internal issue.
Section DI -D Information of the FSM.
cleric670's Avatar
BANNED!!!
There is also a switch in the glove box to disable the trunk release, make sure it's not switched off.
Manual trunk release is accessible by folding down the rear seat. Dig between the seat base and the back rest right in the middle of the seat, there is a red pull cord to release the seat and fold it back. Reach inside and pull the manual emergency trunk release on the inside of the trunk lid.
Handsome Rob
V36 Interior, Exterior & Lighting
Jan 8, 2022 12:09 PM
Cipac
Oct 2, 2018 10:19 AM
dwrecckk
Oct 20, 2012 01:20 AM
BrendanS
Feb 9, 2008 06:55 PM
