Popping Noise
Old Jul 16, 2022 | 12:44 AM
sennie's Avatar
G35
Popping Noise
Can anyone give me some ideas on why my car makes a popping noise when I turn. I’ve replaced the coil over, upper and lower control arms, ball joints, inner and outer tie rods, sway bar links. It’s not a constant noise, but it happens sometimes when I’m usually turning and braking. Any ideas?
Old Jul 16, 2022 | 10:53 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Are you using rubber, poly, or solid bushings for that stuff? You did replace the entire compression rod yes?
The only other thing I can think is that it's actually a brakes or wheel bearings issue.
Old Jul 16, 2022 | 03:37 PM
sennie's Avatar
G35
I believe it’s rubber, and yea, replaced those with the control arms.
Old Jul 16, 2022 | 03:42 PM
sennie's Avatar
G35
Not the wheel bearings but the compression arm. Gotta try the bearing next
Old May 18, 2024 | 10:27 AM
Moneypit35's Avatar
Sedan rwd auto
Did you ever figure it out?
Magneu
May 14, 2020 02:41 PM
BIG JUICE
Jan 10, 2008 02:35 PM
