No crank no start after valve body replaced
Old Apr 25, 2024 | 03:59 PM
Abyss87's Avatar
5 Year Member
I'm receiving u1000 code from a valve body I installed few years back incorrectly, sometimes it starts sometimes it doesn't. Things I noticed after install AT indicator went blank, along with intermittent starting. After being fed up with it I pulled the valve body and discovered a possible culprit, there's an open wire on the TCM, more than likely causing the u1000 code as it has to do with communicating with the TCM. Mended and heat shrunk the wire, I was just wondering could this be my problem I haven't installed the valve body again yet I wanna make sure everything is good before I reinstall. The valve body was purchased from EBay refurbished.
Old Apr 25, 2024 | 10:51 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Could definitely be the culprit, car won't start if the TCM doesn't tell the ECM it's in park/neutral.
Old Apr 26, 2024 | 01:54 PM
G2B35AGN's Avatar
While you've got the valve body out, you could install a TransGo kit just to complicate things a little more
Old Apr 26, 2024 | 05:20 PM
Abyss87's Avatar
5 Year Member
My luck, after finding few exposed wires heat shrinking them and tucking them back in there clamps, I reinstalled the valve body correctly this time... Only still to be met with no start no crank, and the dreaded u1000. So I'm afraid I may have to drop the pan again. Drain the fluid I just put in there and open up the TCM to look for any breaks. I checked my AT CONT fuses, all seent to be good. I'm open to suggestions or any other ideas.
Old Dec 25, 2025 | 08:44 AM
shurur's Avatar
2003 G35 Coupe
Late post.
And just guessing...maybe trans codes need to be cleared. I bought an Autel AL629 for this.
Ant2021
May 30, 2021 08:40 PM
Ant2021
Sep 11, 2019 11:55 AM
da mayor
NorthEast
Oct 12, 2005 07:20 PM
Tfasano
G-SQUAD
Jan 22, 2005 08:43 PM
