Broken Cat Bracket
Old Jan 10, 2026 | 06:17 PM
Mila42's Avatar
Broken Cat Bracket
Hi,
2013 G37S 60k miles.
I found an exhaust rattle on the passenger side near the catalytic converter, specifically where a bracket connects to the cat and transmission..
It seems to have broken off the cat.
I've been driving with that broken bracket for 1.5 years and don't seem to have any issue other than the bracket rubbing against the cat making an annoying sound at 30mph and low rpm.
Wondering if I can just cut off a few inches of that bracket where it's rubbing against the cat, as it's still secured to the transmission and drivers side cat, the o2 sensor and wires are still held in neatly.
Not sure if it can be welded back on or if JB Weld could hold it but cutting it seems helpful. Definitely not looking to replace the cat given it's price.
What do you think?
Pointing to the bracket, beside the passenger cat.
rpm&my_G35
Canada
Nov 16, 2009 01:37 PM
andiz35
Mar 4, 2008 01:30 AM
